Update 2 causing Forest Pack Pro to not render grass
  • Update 2 causing Forest Pack Pro to not render grass
    Working on a project which uses a fair bit of Forest Pack Pro's scattering (grass, trees etc).
    Was working fine with V-Ray 5.10.
    Updated to V-Ray 5.2 and the grass was coming out wrong.
    Went back to 5.10 and the grass is working fine again.
    Don't have time to program test, just thought I'd mention this as happening to me.
    Jez
    3DS Max 2023.3.4 | V-Ray 6.10.08 | Phoenix FD 4.40.00 | PD Player 64 1.0.7.32 | Forest Pack Pro 8.2.2 | RailClone 6.1.3
    Windows 11 Pro 22H2 | NVidia Drivers 535.98 (Game Drivers)
    Asus X299 Sage (Bios 4001), i9-7980xe, 128Gb, 1TB m.2 OS, 2 x NVidia RTX 3090 FE
    ---- Updated 06/09/23 -------
    Thank you, Jez. I wanted install it today, now I will wait. Can not deal with this during running projects. BTW, in you signaturure you wrote, you use 128 GB RAM. In my two machines I have 32GB and I have ordered a new one with also 32 GB. I never had filled the memory full up. How much is your memory used in heavy scenes?
    Workstation: Ryzen 9 5950x @ 4,20GHz 64 GB RAM, NVIDIA RTX 4090, Win10 Prof.<br>Rendernode: AMD Threadripper 2990wx 64 GB RAM, Nvidia Quadro P5000,Win 10 Prof. MAX 2025.2, VRay 6.2, ForestPack, RailClone, RichDirt, KStudio ProjectManager....
      Yeah, I bought the 128Gb for a Cruise Ship Pheonix FD simulation I did a while ago - that was running out of ram when I had 64Gb at the time...
      On this particular project I am working on, doing a render right now, my usage is as follows;
      Ram 74Gb
      GPU1 23.7Gb
      GPU2 18.7Gb.
      I'm doing GPU rendering - and it's with just 3DS Max open only.
      Hope that helps.
      Jez
        Hey Jez,
        Can you define "coming out wrong"? Of course a simple scene will help us the most.
        p.s. one little note - it's 5.1.2, this is still Update 1 but Hotfix 2
        Peter Matanov
        Chaos
          Originally posted by slizer View Post
          Hey Jez,
          Sorry Peter, I was under pressure with this project, so I wasn't paying attention to exact version numbers.
          I'm currently rendering right now with Update 1, Hotfix 1 and will reinstall Hotfix 2 in around 10 minutes and will re-render and see if it is truly an issue with the Hotfix. It definitely was the only thing I'd changed yesterday but maybe a restart of the computer might somehow help
          I'll report back in within the hour.
          Jez
            Hi Peter,
            I tried 5.1 Hotfix 2 and as you can see in the attached work in progress image, the grass is completely different / wrong etc. I cannot describe what it going on, sorry!
            This is a large project file, I'll see if I can find time to send you something over the weekend.
            Many thanks.
            Click image for larger version  Name:	FPP Issue 5.1 Hotfix 2.jpg Views:	0 Size:	1.69 MB ID:	1110945
            Jez
              Ok, we'll try to reproduce it here. Is this some of the built-in presets? Also CPU or GPU?
              Peter Matanov
              Chaos
                Thanks.
                GPU.
                Grass Layer is preset if I remember correctly (sorry, not at computer)
                Jez
                  Reproduced and isolated. We'll fix it ASAP, thanks for the report!
                  Peter Matanov
                  Chaos
                    is this only GPU related please?
                    Martin
                    http://www.pixelbox.cz
                      It's export-related, so GPU and Cloud. Regular V-Ray in Max is fine.
                      Peter Matanov
                      Chaos
                        JezUK the fix is in the stable builds - https://nightlies.chaosgroup.com/mai...ble/stable_5.1
                        Peter Matanov
                        Chaos
