Saving separate channels from VFB ignores Denoiser opacity
  • Saving separate channels from VFB ignores Denoiser opacity
    When you save multiple channels to separate files, the effect result channel apply the Denoiser at 100% whatever the opacity you've specified
    When saving the current channel only, the correct opacity is applied
    Philippe Steels
    Pixelab - Blog - Flickr
    Hi Pixelab
    This has been discussed in detail in the following topic. See if the proposed will work for you, thanks!
    Nikoleta Garkova | chaos.com
      Thanks, it seems to work now
      I guess It doesn't work when you use Lightmix then ?
      Philippe Steels
