VRay Scene Converter crash - CoronaNormalMap with "Additional bump" map
  • VRay Scene Converter crash - CoronaNormalMap with "Additional bump" map
    Hello, I've encountered a bug where the VRaySceneConverter utility will crash completely if it encounters a CoronaNormalMap node with a map in its "Additional bump" slot. This can easily be tested in a simple scene, I attached a screenshot of the simplest shader structure to recreate this.
    I am using V-Ray 5.00.04, and am unsure if this has been fixed in newer versions.
    Best,
    -Josh
    You can try installing a more recent version of vray. I just tested this now and it works as expected on my end. Using vray 5.10.02 build 30700
    pixel bender @ panoptikon
      Hi Josh_H
      I can confirm this is reproducible with 5.00.04, however, I am not able to reproduce it with the latest V-Ray 5 for 3ds Max, update 1.2 version - issue seems to be resolved. For what it's worth, can you try updating as already suggested and see if everything is okay.
      Nikoleta Garkova | chaos.com
        Good to know, I'll check it again when we update our farm and workstations. For now it seems like we can consider this resolved.
