Hello,
I'm trying to make an animation where several railclone objects appear and disappear. I was thinking on just animating the 3dsmax visibility property (from 0 to 1 and vice-versa), but this doesn't seem to work when I try to render with VRAY Next. The railclone objects always stay visible, regardless of the visibility property's value. This happens when the railclone object has a "multi/sub-object" material assigned. When a VRay Material is assigned directly, the Railclone object's visibility partially works. In this last case, the object follows the 3dsmax visibility property (disappears if set to 0.0), but the shadow is still there. Are there any solutions out there for this?
Setup: 3ds Max 2018, V-Ray Next, Railcone 4.21
Thank you!
Thank you!
