blue tint of VRayColor when in sRGB mode
  • blue tint of VRayColor when in sRGB mode
    White VRayColor in sRGB mode renders out with blue tint.
    "ACEScg primares" and "none" modes are OK.
    V-Ray GPU is OK.
    Below comprison - I increased saturation to make this more visible
    Max scene: test blue tint error.zip
    V-Ray CPU 5.10.03, max 2020
    Hi Mnietek2707,
    What if you change the RGB primaries from the Color management rollout (Render Setup > Settings > Color management) to sRGB?
    Nikoleta Garkova | chaos.com
      Sorry for late response.
      I want to use ACES. So changing color management to sRGB is pointless.
      sRGB primaries in VrayColor node should work properly when color management is set to ACES.
        I believe in sRGB white is 6500K, whereas in ACES it is closer to 6000K (not exactly). So what you are seeing looks about right and proper for the white you have chosen (sRGB white is 6500K).
        The color space is part of the definition of the color. So sRGB white is not the same as ACES white.
