vray 5.1.2, render to texture error
  • vray 5.1.2, render to texture error
    Hello there
    I have a little issue here, I can't figure out not even with the help of google.
    Adding VrayExtraTextureMap in the render to texture dialogue causes a max script error - see attached images. The issue is, I can not delete the output item nor can I add any other afterwards. I can edit the items before the culprit though, which means resolution, name, type...
    The same goes for VrayAOMap...
    Max version 2021.3
    What am I doing wrong?
    thx a heap for any hint.
    kind regards
    Hi o-v,
    I can reproduce this on our end as well, so I've reported it into our internal system (ID number: VMAX-11063) for our developers to have a look. Will let you know when we get any additional information on the matter. Thanks very much for the pointer!
    Nikoleta Garkova | chaos.com
      Looks like this is an Autodesk issue, as the same would happen if you try to add Arnold maps like Arnold_map_override. Try using the new Bake to Texture functionality instead and see if you encounter any issues like that.
        Thank you very much for your effort.
        Hens you should change your help and instructions as well... I guess...
        https://docs.chaosgroup.com/display/...ing+with+V-Ray
        Cheers
