Extreme render times using multiple Vray clipper objects
  • Extreme render times using multiple Vray clipper objects
    Hey,
    I'm rendering an engine that's being sliced in by Vray clippers so you can see the inner workings of the engine. I sent the job to the render farm as a tiled job, most tiles took around 2-5 minutes with one area taking around 6 hours. All tiles had a resolution of 1504x676. The tiles in the center of the image took over 1 day, with the longest rendering for 1 day and 14 hours. Unfortunately I cant post the scene file as it's sensitive data. I used default Vray settings except I used BF/BF. Vray Next, Update 3.
    Does anyone have an idea why this happens? I also get strange artifacts in one area that are present in all the passes.
    CGI Artist @ Staud Studios
    We are under implicit NDA for any content you send us (i.e. to support), and can sign any accessory NDA you may need.
    Without being able to see an image, or a scene setup, it's terribly hard to figure out what's doing what.
    Lele
    emanuele.lecchi@chaos.com
    Disclaimer:
