Forest Pack objects don't render if I put them in the Exclude objects list of Vray Toon
  • Forest Pack objects don't render if I put them in the Exclude objects list of Vray Toon
    There seems to be a bug that prevents me from rendering Forest Pack object if I Exclude them from Vray Toon via the Exclude Objects list. They simply disappear during rendering. If I exclude non-Forest Pack objects, the Forest Pack objects render fine, but have toon lines which is not what I need.
    BTW, there's also an error message that appears when I stop the rendering: "Some Forest objects were not built correctly in the last render. See "View Stats" (General rollout) to get additional information about the error"
    Update: I found a workaround. If I use Exclude Layers instead of Exclude Objects, the Forest Pack objects render fine.
    Aleksandar Mitov
    www.renarvisuals.com
    office@renarvisuals.com
    AMD Ryzen 9 9950X 16-core
    96GB DDR5
    Possibly you need to disable instancing in forest pack. Haven’t tried, but might help (if the scene is not too big).
      Seems to work fine here on a simple test scene:
      Maybe it is something scene specific ?
      Yavor Rubenov
      V-Ray for 3ds Max developer
        Not for me. See below. I've just sent this scene for inspection to support's email. The ticket number is: 342-837-7186. I forgot to mention that I'm using the latest official version of Forest Pack Pro - 7.1.1
        Click image for larger version  Name:	forest_pack_toon_object_disappearing.jpg Views:	0 Size:	185.6 KB ID:	1115220
        Aleksandar Mitov
        96GB DDR5
          Same here...They disappear and I get the Forest pack error message.
