Hello,
Since a couple of days I'm dealing with a really strange "issue"...
Since the day before yesterday, out of the blue, for no apparent reason when rendering scenes in 3ds Max 2020, Vray no longer utilize the CPU OC (in my case 4,4 GHz on all cores) that is set up in the PC's BIOS.
The issue manifests only when using progressive rendering method. When using Bucket method the issue disappear. Frankly I have tried all methods to identify what might cause, including re-rendering old scenes, but no luck...
I consider this issue very strange because I haven't changed or installed anything lately with the exception of the latest 3ds Max 2020 security fix update...
I have attached two screenshots that somehow manage to illustrate the "issue", but the strangest thing is when the render builds the light cache the CPU doesn't downclock, it starts to downclock in the moment when the progressive render starts.
My hardware/software setup environment is the following:
OS: Win 10 64 Bit 20H2 (Windows Feature Experience Pack 120.2212.2020.0)
RAM: 128 GB DD4 ~2666 MHz
CPU: Intel® Core™ i9-9980XE Extreme Edition Processor @ 4,4 GHz all cores
Mobo: Asus ROG Rampage VI Extreme Omega
Autodesk® 3ds Max® 2020 (2020.3.4 Security Fix)
Vray Next Update 3.2
Forest Pack Pro 6.2.1
Corona Renderer 5 hotfix 2
Any help/suggestion would be much appreciated given the fact that is a very strange manifestation.
P.S. I have also tried and installed Vray 5 but no avail...the issue still manifests
