Faild parse of preloaded OSO code
  • Faild parse of preloaded OSO code
    The following error message is displayed when reading a max file in certain environments.
    (I didn't reproduce it on my PC.)
    Unable to parse preloaded shader "shader #########"
    The scene was created with 3dsMax 2021 V-Ray 5.1 and loaded with 3dsMax 2022 V_Ray 5.1 update 2.
    What is the cause of this error?
    OakCorp Japan - Yuji Yamauchi
    oakcorp.net
    v-ray.jp
    I find a question similar to the Autodesk forums, but the cause is unknown.
    Does Chaos know anything?
    https://forums.autodesk.com/t5/3ds-m...3/td-p/9942857
    https://forums.autodesk.com/t5/3ds-m...y/td-p/8997992
    oakcorp.net
    v-ray.jp
      Hi flat,
      Not sure here, have you tried reinstalling V-Ray/resetting the 3ds max settings to their defaults by deleting the ENU folder? You mentioned this happens in certain environments, can you clarify a bit more here; Does it happen only with this particular scene?
      Nikoleta Garkova | chaos.com
