I came upon a strange thing while attaching my objects into one. A particular object's material changed appearance. I've checked the materials IDs after attaching and they are all fine. If I detach it to separate objects again, the material changes back to the original look. Please see screenshot below.
Attaching objects into one changes their material appearance
Last edited by Alex_M; 11-06-2021, 07:38 AM.Max 2023.2.2 + Vray 6 Update 2.1 ( 6.20.06 )
AMD Ryzen 7950X 16-core | 64GB DDR5 RAM 6400 Mbps | MSI GeForce RTX 3090 Suprim X 24GB (rendering) | GeForce GTX 1080 Ti FE 11GB (display) | GPU Driver 546.01 | NVMe SSD Samsung 980 Pro 1TB | Win 10 Pro x64 22H2Tags: None
Not sure. Could you strip down the scene and attach it here or send it via the contact form? Address it to me in the subject and include a link to this thread in the message.
Sure, see attached.Max 2023.2.2 + Vray 6 Update 2.1 ( 6.20.06 )
Thank you for the provided scene. The issue is caused by two things - the Rounded corners on the big cylinder and the refractiveness of the small cylinder. I am not yet sure if this is a bug or a byproduct of the rounded corners' effect. I'll write again with more information.
EDIT: Setting the Rounded corners mode to Convex only resolves the issue, so you may use it as a workaround.Last edited by hermit.crab; 18-06-2021, 09:23 AM.
- Likes 1
