Filmic Tonemap Ruins Edges with Alpha
  • Filmic Tonemap Ruins Edges with Alpha
    When Filmic Tonemap is on and applied to a saved EXR with an alpha channel the soft edges have a halo. It looks like the Tonemap applies to the RGB data without first properly un-multiplying the alpha.
    You can especially see this is soft focus areas when using DOF.
    This makes it kind of useless here. We are running a stable nightly from about 2-4 weeks ago. I can find the actual version of it matters.
    Hello,
    Data out of V-Ray is not premultiplied so it doesn't need any unpremultiplying. Overall what you describe seems like the one described here:
    https://forums.chaosgroup.com/forum/...-alpha-channel
    Yavor
    Yavor Rubenov
    V-Ray for 3ds Max developer
      Yes, similar if not the same issue.
      It has the appearance similar to the alpha multiplication issue I mention, even though, as you say, VRay isn’t premultiplied directly.
      Is there a fix in the stable branch? I think you said it was identified in the other thread.
      Thanks.
        As Aleksandar explained here https://forums.chaosgroup.com/forum/...06#post1092706 - no issue to fix.
        Yavor Rubenov
