Hi everyone,
just as a confirmation, is right now impossible to transfer attributes from an alembic particle sequence in a vrayproxy down to the vrayinstancer?
I've seen the new emit only method and got it to work perfectly for position, orient, scale, etc (very appreciated by the way thanks!), but still i can't forward custom attributes that i usually transfer via vertex color. If i render vrayproxy as sphere/points it's fine.
I've seen that in the documentation, it should be possible to use the particle system shader (at least with particle flow), is it still not the case with vproxy/alembic right?
Thanks guys and keep it up the good work.
fede
fede
