Noise reduction of vray5.12
  • Noise reduction of vray5.12
    Vray 5.12 when I used noise reduction elements, I turned on noise reduction option in reflection elements. But the final result of rendering shows that the reflection elements still have not been de-noising
    Can be normally de-noising next
    Hi q976431,
    Seems to be working as expected on my end, see denoised vs undenoised result. Make sure that you've added the VRayDenoiser Render Element and the Denoise option is enabled on all the reflection/specular REs. Alternatively, do let me know if I've misunderstood you. Thanks!
    Nikoleta Garkova | chaos.com
      Yes, that's what I do. I use Intel noise reduction
      I've turned on the noise reduction option in reflection. But only RGB images are denoised. Other rendering elements have no effect
        Hi, Have you try V-Ray default denoiser?
        Jackie Teh
        3ds Max 2023, V-Ray 7 Hotfix 2 [7.00.08 build 00000]
        AMD Ryzen 9 7950X 16-Core Processor@4.50 GHz | 64GB RAM | Nvidia RTX 4090
        Website: https://www.sporadicstudio.com
        Email: info@sporadicstudio.com
        YouTube: https://www.youtube.com/c/SporadicStudio
          Yes. I use three noise reduction modes, and the problem is the same
