Opacity maps
  • Opacity maps
    I can't figure out what I'm doing wrong with basic opacity mapping.
    I have alawys used the same method but not it doesn't work. I know I am not using the correct settigns somewhere but can't figure out where.
    I have a map I have used for many years. for instance a cutout of a person or a tree. tree.tif. it has alpha channel. Using vray material I set diffuse color to black and reflections to black. I put the map in the diffuse slot and also in the opacity slot. In the opacity slot I set filtering to none and alpha source to image alpha. What I get is a bunch of dots. The opacity map generates the diffuse as a bunck of dots. I have tried the various opacity modes like clip and stochastic. that does not help.
    I don't get it. This used to be so easy. What am I missing?
    TIA for any help.
    mark f.
    openrangeimaging.com
    Max 2025.2 | Vray 6 update 2.1 | Win 10
    Core i7 6950 | GeForce RTX 2060 | 64 G RAM
    cancel this. I somehow got it working sheesh. maybe had to do with setting mono channel output to alpha in the opacity map. not sure.
    mark f.
