VrayDisplacement --> wood-grain-like disruption on the surface
  • VrayDisplacement --> wood-grain-like disruption on the surface
    Hello Everyone,
    when I work with VrayDisplacementModifier, I get this fine wood-grain-like disruption on the surface.
    These are not part of the textures.
    I don't find the fault. Has anyone had similar experiences? What could be the reason?
    Regards,
    Balazs
    ... looks a bit like a jpg in 8 bit?
    Use 16, better 32 bit on disp.tex.
      It looks like banding in the map you are using, so maybe it's a compressed image.
      If you link to the specific map you used then it's easier to tell.
        The image is exported directly from Substance Painter, but that's correct, only with 8-bit. I have to try 16 or 32 bit
          Ensure the 16bit is *floating point*, not integer, and you should be fine without the need for 32bpc (which is always FP).
          Lele
          emanuele.lecchi@chaos.com
          Disclaimer:
