Fog Color Issue
  • Fog Color Issue
    I am getting an issue when using fog color (for example for water materials) in combination with objects with very flat angles pertruding the surface.
    Attached you can see a picture. You can see for the left plane there is this unnatural thick dark line at the intersection. Once the plane has a steeper angle the line disappears.
    The line disappears when the fog color is set to pure white.
Name:	WeChat Image_20210928234310.png
    Check out my FREE V-Ray Tutorials
    It's to do with shadow bias, so will disappear if you set it to 0.
    However, it doesn't work with only an hdri (or I can't figure out where to adjust any bias for the dome), so you need a sun also to make it go away.
    Of course the dome's bias is in the sampling rollout, so all solved
      Awesome that works! Thanks That's the first time I ever had to change the bias so now at least I know what it's good for!
        I knew that it had been reported before...just took me a while to locate the post, so credit goes to whoever solved it there
