Bug That Causes Script Error
  • Bug That Causes Script Error
    Hello,
    This is an issue that's been around for awhile, and I'm surprised it hasn't been resolved yet.
    1. Make sure your renderer is set to V-Ray 5.
    2. Create a box (or any object).
    3. Select the box.
    4. Press the "X" key. (This should open a quick search text box)
    5. type: uv
    6. You should now have a script error in "vrayutils.ms"
    I've been able to repeat this issue on more than one machine, so I would be surprised if it doesn't happen to you. It only happens the first time you type it. Typing it again will not result in the error. Why am I typing "uv" in the search box? Because it's a quick way to apply a UVW Map to your objects. Let me know if you need any additional information.
    I have been able to repro this, thanks for pointing it out!
    Lele
    emanuele.lecchi@chaos.com
    Disclaimer:
