Clear Previous render not working in Update Vray 5
  • Clear Previous render not working in Update Vray 5
    I am trying to render an animation using layers as a mask. I have change the previous render setting to clear, however it is not clearing the image and rendering over the top leaving the trail of where the objects are.
    All of my settings are correct its just not clearing the render
    regards
    Paul
    Correct me if I'm wrong, but I think this thread was meant for the 3ds max section of the forums, right?
    Otherwise, thanks for the report. The issue does appear there in the latest Update. I've logged it (internal bug-tracker id: VMAX-11568 ) for developer investigation.
      Yes Sorry.
      thank you for that. for others I have rolled back a version and it works fine
      thanks
        I thought this issue was resolved.
        www.mirage-cg.com
          This is fixed in the stable nightly builds starting with build 31072 (https://nightlies.chaosgroup.com/mai...e_5.2/20211029)
          Sorry for the inconvenience.
          Yavor Rubenov
          V-Ray for 3ds Max developer
            Thank you Ruben. I have a question. Are there any other big issues similar to this that you are working on fixing? I ask because if there is another fix coming out in a week I would much rather wait and do a re-install on the machines I use just once.
            Thanks in advance and thank you for the fix.
              We are still gathering feedback on the new update - so there might be some other fixes coming up.
              Yavor Rubenov
                Hi guys
                thanks for the feedback. Has this issue been resolved in the November update?
                regards
                  Yes it's resolved. Sorry for the inconvenience.
                  Yavor Rubenov
                    Amazing thank you
