Lens effect all over the place after last update
  • Lens effect all over the place after last update
    maybe it's because I load .vrimg files after I batch rendered them? This is what it "highlights". There is nothing behind that. On some scenes it only affects the edge of the screen, correctly then, I mean the effect is in the right place but only on edge of the render.
    Also when I apply the new sharpen the whole image becomes like a collage, completely messes it up.
    Oh and I tried enable off and then on again so it recalculates it but it's the same.
    While I'm here...that bug I posted like a year ago (and it was said to me that it's confirmed but difficult to fix) is still there. Where visible vray lights won't be visible behind the glass if they have direction higher than 0.0. That is totally killing my workflow since I use them as LED ceiling lights etc and this is the fastest way.
    www.hrvojedesign.com
    Hello,
    Can you share some of the vrimg files showing those strange lens effects ?
    Yavor
    Yavor Rubenov
    V-Ray for 3ds Max developer
      Yes of course. I can send you a couple. Where to?
        You can attach them here or send them our support.
        Yavor Rubenov
          Ok so I just figured it out. I usually save presets and load them. That's the problem. So now when I loaded the vrimg in a clean scene and turned on lens effect it was ok. Will see if it happens again. Do you want me to send them anyway?
            If you have a vrimg and a preset that cause this together - then yes send them. There might be some issue that happens with the preset.
            Yavor Rubenov
              Nope...it happened again. So I tried a bit of editing, change the lens effect size, and it turned back into that weird one. Sending you via wetransfer with link to this thread. It's 150MB.
                For the preset I only added filmic tone map. And I can't reset it...I guess I would have to switch max render back to default and vray again or restart max? Since clearing vfb doesn't help.
                  So basically you have to navigate through a mindfield...turning on denosier kills lens, turning on sharpen kills everything...I don't know. Try loading and applying these things. Also try changing the size in lens effect, even on earlier versions the size didn't work properly, like it would be gone at certain lower sizes and come back on higher ones.
                    Hey,
                    have you received my files?
                      Dear Crayox13, hello.
                      Your files are now found and downloaded. But to avoid this slowdown and confusion, from now on please share files or submit requests via our contact form.
                      You will receive a ticket number which could be shared to check the progress, also we use now SendSafely to receive files from customers easily.
                      When it is a scene related issue, please choose 3D and rendering help under Request type.
                      That way you will speed things up and we will be able help you faster.
                      TS
                      Tsvetomira Girginova | chaos.com
                      3D Support | contact us
                        Ok thanks, will in the future. Please disregard the second wetransfer (VRK new ones) as it was sent mistakenly to you. Didn't delete your email when I was sending it.
                          Thanks for the files - I'll check what is going on and get back to you.
                          Yavor Rubenov
                            Yep found the issue - happens when you have resolution > (~1650 x 1650) and calculating all the effects. Fix is on the way.
                            Sorry for the inconvenience.
                            Yavor Rubenov
                            • #15
                              Cool thanks. Can you please check the status of that vray light bug? It's really killing my workflow. All "LED" lights inside the house, or spot lights for that matter (I often just use visible discs on the ceiling) are black behind the glass if they have directional other than 0.0
