Exposure not working adequately V-ray update 2.
  • Exposure not working adequately V-ray update 2.
    The exposure in the camera is corrected as strange as possible. As if there is some kind of obstruction from overexposure.
    With an increase in ISO, the exposure changes to a certain value. Further increase does not result in changes.
    Similarly, when adjusting EV.
    I try merged this sceen in new file, but the same.
    I make the new file for test, similarly.
    On screens can see what somthing change, but not correct relatively exposure correction.
ID:	1129065Click image for larger version
ID:	1129066Click image for larger version
ID:	1129067Click image for larger version
ID:	1129068 The exposure in the camera is corrected as strange as possible. As if
    Everything seems to work as expected on a simple scene. From what I understand you've reproduced this on a simple scene as well? Could you share it (or alternatively this particular scene)?
      Does it happen also with a v-ray physical camera?
      Lele
      emanuele.lecchi@chaos.com
      Disclaimer:
        I was delighted with the 2.1 update and loaded the scene above.
        The situation has not changed. Created a new scene.
        The exposure is adjusted a couple of times, then the process is similar to the one described above.
        The physical camera and the v-rey camera are the same ..
        In some segments, changes occur, for example, if you raise the shutter speed too much. But there is still zero reaction to the change in the ISO.
        In general, you can somehow darken, but not lighten.
        In this case, the exposure works with the switched on virey light, and reacts to it. but not the atmosphere (sky with a tied sun).
        In general, something changes, but it works strange and unpredictable.
            So it starts working if you add light. At the same time, there is no reaction to the atmosphere.
              Works fine with Sky and Sun (and Sky only) as well. Are you using the default render settings? Also, could you send a screencap of your exposure control setup (Rendering>Environment (shortcut . Or better yet attach the fresh scene here.
                Render settingfs as default. Cange just burn value 0,5 in color maping settings.
                Exposure control as default.
                  first sceen
                  https://drive.google.com/file/d/1klR...ew?usp=sharing
                  second defaul new sceen
                  https://drive.google.com/file/d/1Suj...ew?usp=sharing
                    Turn off, of raise as needed, Max Ray Intensity in the general render options.
                    What you're seeing is the MRI limit come in effect, as the interior is entirely indirectly lit (as your sky is in the background slot, instead of a dome light.).
                    Lele
                    Disclaimer:
                      Oh, greate! It's working. Thank's man!
                        You're very welcome.
                        I left it somewhat implicit, but if you move the sky/hdri into a domelight, you can leave MRI active at defaults, as the dome counts as direct lighting, not indirect.
                        Lele
                        Disclaimer:
