Outline around rendered objects when using vray sky
  • Outline around rendered objects when using vray sky
    This is driving me crazy. I'm trying to render certain elements to composite later, but an outline keeps showing up in my renders around my objects. I tried EXR and PNG with alpha settings, and I tried various environment settings. I tried using a dome light with default vray sky as the map. My environment is set to pure black. Argh. Someone tell me what I'm missing please. I am using GPU rendering.
    Are you sure your dome is set to invisible? It may seem obvious but I am always forgetting that
    I wish it would sanity check itself and put up an alert before rendering....maybe one for the wishlist...
      Yes it is. I dont know what else to try.
        Best idea is post a stripped down scene with just one object in it, plus the lights etc. and someone will be able to troubleshoot it for you.
        I would do so, but I am rendering so wouldn't be able to until tomorrow.
          Do send a simplified scene either here or via the contract form so we can take a look. Usually, setting the Environment colour as black should suffice. Are you certain there aren't any other lights/background which may cause the outlines?
            I'm not sure. I have a ton of lights in the scene. But I never usually have this iussue with other lights.
              Well, do send the scene as instructed above so we can troubleshoot.
