Max hangs if trying to open file with Vray 5 update 2.1
  • Max hangs if trying to open file with Vray 5 update 2.1
    If I try to open a file in Max 2022.2 with the latest version of Vray, Max hangs at infinity and I need to kill it using the task manager. If I uninstall Vray, I can open the file (but obviously, without my materials and render settings), How can I attach a Max file here so you guys can take a look?
    Ok this was an issue with some preferences on the procedural texture maps, so problem solved, if needed this thread can be deleted.
      Hey davius3d, I might have the same problem(plus it takes 10 minutes before to start calculating the GI when I try to render).
      but only "procedural" materials I'm using are from substance.
      Which settings did you change If I can ask?
      Thanks in advance,
      Lorenzo
        Hey Lorenzo!
        The problem was the resolution I did set for the procedural maps (when you press ALT+B on your viewport, and go the the left tab, there are option to change the resolution of procedural maps, bitmaps, an environment maps. Those apply only to the viewport, so it should no interfere with rendering speeds at all.
