VRayBlendMtl + MatID
  • VRayBlendMtl + MatID
    I am getting strange results when using VRayBlendMtl and trying to use Multimattes set to MatID.
    Basically there is no Blending, it's either MatID 1 or MatID 2. I would assume there should be a gradient happening so that there is the same result such as in the RGB color.
    Check out my FREE V-Ray Tutorials
    Yes, that's already known (internal bug-tracker id: VMAX-10476). I'll add your request for the feature's implementation as well.
      Hi, thx for the info! I just tried in V-Ray 3.6 and the same bug is present, so it seems this has never really worked correctly yet. I will keep my fingers crossed that it will be fixed in some of the upcoming releases.
        Oh, it did work: i made a few compers very happy with it over many years.
        It broke at some point, and wasn't noticed, somehow, but it's being worked on as we speak.
        EDIT: It turns out i remembered wrong: the traditional Multimatte never did fractional coverage.
        My scripts from a while back, indeed, pointed at a wholly different approach based on custom passes.
        The revised code ought to make MMs a lot more user friendly, and also help reduce the number of REs required for any given task.
        Lele
        emanuele.lecchi@chaos.com
        Disclaimer:
