Hello,
I'm having a DR rendering issue where some buckets are rendered differently than the others.
Upon research, I found that if I use my workstation as "localhost", my computer renders these artifacts.
If I start VraySpawner and use the same machine as a server, all buckets match with my 4 other render slaves.
As localhost:
As render slave:
At first, I thought the issue is caused by my workstation being AMD 3990X and my render nodes all identical i9's, but since I found a way to achieve correct results with my workaround, I think this is a bug. It would be okay, but rendering like this the per-frame time is slower.
My system is 3ds Max 2020, SP4
Vray 5 update 1.3
Thank you in advance,
Joosep
As localhost:
As render slave:
Vray 5 update 1.3
Joosep
