Using windows 10, 3dsmax 2022.2, and the latest nightly of Vray. I try and import a .tx sequence as a, well, sequence and max crashes. If I import an PNG sequence, then manually change the suffix to .tx in the generated.ifl file, it seems to work fine. Might this be something internal to MAX not recognizing .tx as a filetype?
Trying to import a .TX sequence in vraybitmap crashes max.
I'm importing the .tx sequence as an IFL sequence, using the import dialog. Here's a video. Empty scene, new VRayBitmap, set assigned to a dummy .tx file, then I try and assign a sequence to it.
https://drive.google.com/file/d/1Zet...ew?usp=sharing
Please confirm that this is a crash bug - possibly you should disable the "import tx as sequence" from your UI, or find some way to quietly handle this in the background (have the VRayBitmap generate the .IFL itself, for instance). I've tried this on 3 different computers and it is an insta-kill of 3dsMax every single time.
