hello. i'm in max 2021 and since v5, i've noticed that when i create a vray light, the target distance is available for me to type in or use up/down spinner when the targeted check-box is un-checked. however when the targeted check-box is checked, then the distance is greyed out and i cannot change it. is that correct behavior?
also, the same thing happens when i create a vray physical camera. if targeted is checked, then i cannot set the target distance via the spinners or text-box.
