Offcourse it has glossy reflection and I know its highlight from the sun but problem is it looks wierd like bad reflection antialiasing. It should be continuous and not dashed on continuous line.
Is there some anialiasing control for reflection like in scanline in max has for material where you can control it in raytracing settings.
what is the value of your vray light?
You can get this issue with a really large value in the vray light area.
the reason is that if you have a pixel value of say 50 next to a pixel value of .5 (your example is a perfect case for this to happen) then the aa has big problems (not just vray's) to create all teh values is needs in the 1-2 pixels that it has to create a soft transition.[/quote]
