Vray Sun glare not working
  • Vray Sun glare not working
    Hi guys,
    I'm having an issue in this particular file where my vray sun isn't creating a sun flare lens effect. I have lens effect enabled, vraysky in the environment slot. when I create a completely new scene it works fine. so I tried to merge this scene into a clean file, and even created a new vray sun and sky map...still no lens effect showing. The glare does work for other lights in my scene though. bizarre. Any ideas?
    Thanks guys
    is the sun maybe set to invisible?
    Kind Regards,
    Morne
      Hi Morne. No it's not. I checked that...a few times actually.
      thanks
        I found that the lens flare is visible, though only when something is occluding the sun.
        On an empty scene it's not visible, if that helps.
        EDIT: Interestingly, it is sort of what you expect if you drag the sky to the material editor, then tick the 'specify sun node' box but leave the sun light at 'none'.
        Then you can just tweak the intensity etc. I'm sure that's not how it's meant to be used but may be useful if you still have problems
          thanks fixeighted.
          I'm not entirely sure what you mean. it has always worked for me, and on an empty scene it works fine. do you have this issue often?
            Sorry, I just woke up so a bit bleary still .
            I initially left the sun at 1.0, so the flare did not show without occlusion of course. Reducing intensity made it pop back in as expected.
            Maybe you just have a glitched scene. Post it stripped and I'll see what I get here.
              Do you have an aerialperspective effect active?
              A.
              www.digitaltwins.be
                Hi Ashley. Nope... No atmospheric anythings.
                  so i tested an HDRi...works as expected. It's only the vray sun
                    Try this:
                    - Recreate the sun and VraySky
                    - Reset VFB lens effects
                    - Reset Render settings
                    A.
                    www.digitaltwins.be
                      I've done the first two a few times. will try reset the render settings. thanks
                        Nope...didn't help
                          I even created a completely clean scene with a simple teapot and it's not working. See attached.
                          An hdri works though...
                            Ah I see now
                            It works fine in your scene Terri
                            The issue is your sun is not in view.
                            Remember the sun does not appear in your render view in same place as what you see in viewport and it's icon representation in view. Its actually much much further away. So if just move your sun a bit left and down in your view, then you will see the sun disk and it will receive lens effects
                            Kind Regards,
                            Morne
                            • #15
                              but the sun IS in the viewport. am I missing something? this has always worked before with a similar setup
