vraydirt
  • vraydirt
    Vray gives me headache this week. Some problem with progressive caustics now vraydirt. This is simple setup and I am pretty sure it worked in the past. vray material with vray color applied to to base and coat material (to vrayblendmaterial), vraydrit in blend slot. When I change values in vraydirt material under IPR it freeze (if I type different value in any vray slots)/or crash max (if I use spinner to change the values). No mini dump, just info I have attached. I have tried in 3dsmax 2019, 2022, latest vray and previous build, windows 7.
    Best Regards
    Tomek
    Portfolio: http://dtown.pl/
    Just checked with old max2014 and vray next and this setup works fine on my computer...
    Best Regards
    Tomek
      Could you attach the scene so we can test it out?
        The scene attached. Thank you Aleksandar!
        Best Regards
        Tomek
          Thanks for the provided scene. We did some tests, however, we cannot reproduce the crash (win 10, latest official V-Ray, 3ds max 2022). One thing I didn't understand - are you on Windows 7 or have you just tested it there?
            I have my workstation set up on windows 7. I had similar problems with vraydecals but it was fixed in the latest build and I was told that it was 3ds max 2019 specific, but here I have tested it in 2022 too.
            Best Regards
            Tomek
              I had another attempt and crash but this time there are some dump data attached so you could have a look. Thank you!
              Best Regards
              Tomek
                The crash seems to be Windows 7 specific. I've logged it (internal bug-tracker id: VMAX-11774) for developer investigation.
