Not able to use Lightmix feature
  • Not able to use Lightmix feature
    Hi!
    I'm using the Lightmix the first time but can't get the Lightmix feature working. I have 3 lights in my scene ( Indoor, VRay Sun and 2 Planelights ).
    Lightmix Renderelement is added but it doesn't create any element.
    When rendering is done and i'm trying to change Source form RGB to Lightmix, there's always the message telling me to add Lightmix RE an re-render.
    When hit re-render it jumps back to Source: RGB after rendering finished again -> please add lightmix renderelement and re-render.
    Is this a bug or did i missed something to set-up ?
    Update:
    When using Brute Force instead of Irradiance Map the Lightmix works
    If BF is required, it may be helpful to add it to the LightMix documentation:
    https://docs.chaos.com/display/VMAX/VRayLightMix
    Hi you are right. The LightMix is not supported with Irradiance map. It only works with Brute force. I logged you request for improvement of the docs page (DOC-8939).
    Vladimir Krastev | chaos.com
