Hi! I need some help with a basic animation render. I've set up a camera that moves around a pedestal. All the renders are still frames at 3840x2160. They are rendering well in the VFB but when they save as a jpeg they're cropped into the top left corner surrounded by a black background. As a result, the output of the cropped image is a quarter of what it should be. I assume there's some output button somewhere that controls the size/cropping? Ultimately, I just want the final jpeg to be full size and fill the black space. Could it be a camera setting?
Renders saving quarter size
Ensure the VFB button for test resolution is off (short click).
Notice it will still show the last selected test resolution number (f.e. 50%).
Execute this line of maxscript to be sure it's truly off (if the UI isn't as communicative as you'd like it.).
Code:vfbcontrol #testresolution off
Lele
emanuele.lecchi@chaos.com
Disclaimer:
- Likes 1
Originally posted by vladimir_krastev View PostEdit: I did not see Lele's post before sending mine.
It's good we both said the same thing, imagine the embarrassment otherwise... ^^
Lele
Disclaimer:
