Max crash with VrayDirt+VrayOSLTex
  • Max crash with VrayDirt+VrayOSLTex
    3dsmax 2019 (though it also happens with all max versions after)
    vray 52023
    Steps to reproduce:
    1) open the attached max file
    2) connect the VrayDirt to the VrayOSLTex input (see screenshot)
    3) press render
    The render process should start, freeze, and after a while crash max. If you replace the VrayDirt with something else (like a checker texture) it'll render fine. So something with how the VrayDirt is evaluated seems broken.
    Are you on windows 7?
    Best Regards
    Tomek
    Portfolio: http://dtown.pl/
      Windows 10
        I was asking as I had 3dsmax crashing case some time ago (vraydirt+blend material) and windows7 was blamed.
        Best Regards
        Tomek
          Hi thank you for your report. We reviewed your scene and logged the issue under VSLANG-162 in our bug tracking system.
          Vladimir Krastev | chaos.com
            Hi, the crash with VRayDirt applied to VRayOSLTex issue is fixed. You can download the latest V-Ray and test it.
              Thanks for the update! We have however completely abandoned OSL for one and a half years now and won't be coming back - with this being one of the main reasons why. We simply can't wait years for a bug fix (and that one certainly could be called a severe one).
