Vray Menu Bar display problem
  • Vray Menu Bar display problem
    Hi. I just installed Max 2023 and Vray version "vray_adv_52023_max2023_x64". I'm adjusting the UI, I have 3 monitors with different resolutions and orientations. I like to keep the vray menu bar off to the left monitor. I've been doing this for years in many different versions of max and vray. Now it's all wonky. When I drag it there's regularly a distance between the drag icon and the bar itself which makes it especially hard to move it anywhere at all. I can't drag it over properly. Sometimes if I get to close to the left edge, the bar kind of snaps over so that it's half off screen. I was able get it back in place by restarting max. But now it's half offscreen on my center screen, but the drag part is not visible on the left screen where the other half should be. And restarting max isn't helping.
    The reason why I started doing this, is because I have a 4K center monitor and the vray buttons are always too small (smaller than the regular max buttons). I mentioned this in a previous post some years back, and I don't know if this problem has ever been solved. I'm sure many people have 4k monitors by now, so I can't be the only person with this problem.
    Help.
    Hi it is a bit difficult to tell what is going on. Maybe you could contact us on the support page. From there we might need to log into your computer to try and help.
    Are you sure this is a V-Ray related issue? It could be a 3ds max problem.
    Vladimir Krastev | chaos.com
