IPR not working anymore after using batch render for a scene - what could be the reason?
  • IPR not working anymore after using batch render for a scene - what could be the reason?
    Hello,
    I was using batch render (.bat) with command-line render with some scenes.
    Since that the IPR is not working anymore with those scenes.
    (but with other scenes, which have not been involved)
    I can start a standard render but no IPR anymore.
    What could be the reason? Does it change any setting?
    Thanks
    Max 2022 and Vray5
    Just tested it out on a simple scene without issues. Any warnings printed in the log? Does it happen with regular Batch rendering?
      Thanks, I found out with the LOG:
      "Skip existing frames" disabled the render - which shouldn't do it with IPR which is just used to check the render.
      Also it's mentioning things, that weren't true, like distributed rendering, which is off.
      Attached screenshots
Name:	vray IPR not render.png
Name:	no distr render.png
ID:	1148420Click image for larger version
Name:	skip existing frames.png
        You're right, it shouldn't happen with IPR, however, I'm not getting that warning even though "Skip Existing Images" is enabled (tested with update 2.3). Which V-Ray 5 build do you have installed? Also, you can safely ignore the "Distributed rendering is not supported in production IPR mode" message. Also, note that you can utilize our own V-Ray output settings.
