OSL Reflect Refract Bug
  • OSL Reflect Refract Bug
    I've found some irregularities using OSL map and VrayMtl. When connecting the reflect map, refract map, refl gloss and refr gloss at certain combination of values refraction or reflections disappear.
    I've simplified the code to illustrate the problem.
Name:	Screenshot 2022-05-19 142657.jpg
ID:	1148536Click image for larger version
Name:	Screenshot 2022-05-19 142835.jpg
    This should look like normal glass material, but because everything is set to 1 it looks like a grey ball with no reflections.
Name:	Screenshot 2022-05-19 143056.jpg
    When I put the Reflect gloss to 0.99 instead of 1.0 the reflections return. Still no refractions though
Name:	Screenshot 2022-05-19 143307.jpg
    can't add more attachments, too be continued
    To get everything too work as expected I need to put 1 of the maps to a higher value (1.01 for this example), just 1, if I put them both on the same impossible high value then it breaks again.
    And I need to clamp the refl gloss to .9999.
Name:	Screenshot 2022-05-19 143501.jpg
ID:	1148542Click image for larger version
Name:	Screenshot 2022-05-19 143519.jpg
    Thanks for listening to my ted talk.
      Thank you for the feedback. We will look into this and get back to you.
      Milva
      Milva Perkovich
      QA department
      Chaos Group
