Noise
  • Noise
    I am having a strange problem. I installed V-Ray 6 and had issues with Forest Pro, so I uninstalled it and reinstalled V-Ray 5. I was working on an interior, which I don't do much of, and I couldn't get past the noise issues. I didn't think it was a software issue, so I shelved it and went to work on an exterior, which I do hundreds of. Now, the exterior is having the same noise issues. One hour of render is always enough with Denoiser at .4 in the layers. Now, even setting the denoiser to 1 and two hours later, the noise is so bad the image isn't usable. So what happens when you install 6, remove it, and install 5? Is there something left behind that would cause this? I can toggle the denoiser off/on and see that it is working, but not good enough. On the interior, the progress seemed to stop working altogether, and the VFB stopped getting cleaner.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    I can't say what's exactly causing this. But if you are working on the same file, it is always good idea for such cases to reset render settings by changing the renderer from VRay to something else like Corona then back to Vray to make sure there is no any left over from the other version.
    Simply, I love to put pixels together! Sounds easy right : ))
    Sketchbook-1 /Sketchbook-2 / Behance / Facebook
      Yes, that is usually the first thing I do.
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
