How to open exr settings when using "V-Ray raw image file" export?
  • How to open exr settings when using "V-Ray raw image file" export?
    Hello, I need to render an animation with denoiser render elements. The renderelements are only saved in the image when I use "V-Ray raw image file" to export the sequenz. But there is no Setup or Gama override option like when using the 3ds Max Render Output.
    Is there a way to acces this setup when using "V-Ray raw image file" ?
    Try adding the VRayOptionRE render element...
    Kind Regards,
    Morne
      Thank you, I didn't know about this. But there seems to be no option to save as 16 Bit.
        The default color depth of EXRs is 16-bit. You can switch to 32-bit in the V-Ray Raw Image File output browser options.
          Thank you. It's a bit confusing because Photoshop seems to think default EXRs are 32-bit.
            That's because PS lacks the 16bpc *float* workflow entirely, so all it can do to preserve the range is to promote them to 32bpc (doubling memory usage for the channel, in the process.).
            Even the 32bpc one is lackluster at best.
            Lele
            emanuele.lecchi@chaos.com
            Disclaimer:
