Vray6 - Vray Blend Material - Compact Material Edititor - CANNOT RIGHT CLICK
  • Vray6 - Vray Blend Material - Compact Material Edititor - CANNOT RIGHT CLICK
    3D Max 2021. Vray 6.
    Tested on two machines and problem is 100% there. I cannot right click in my VrayBlend material editor anymore to copy/paste coat materials or blend maps. Same with the base materialc slot. Once I have a vray material assigned and am working within that I can right click again.
    This is a big problem becasue I tend to copy/paste my materials and now cannot.
    I can right click on areas outside the actual slots. Somehow only the slots are not fuctional.
    Actually it's a bit more than what you found, at least for me.
    If there is a map in a blend slot, then the only right click option available is 'clear' whereas there should be a list of usual options.
    With the base, the paste options are missing and with coat there is only 'clear' (if a mat already there).
    This is with Max 23 and Vray 6 compared to Max 21 with Vray 5, 2.2
      Hi this is caused by updates in the user interface. It is now using QT for better performance.
      Vladimir Krastev | chaos.com
        To add a bit to this (and sorry for putting part of the blame to others again ):
        - For Max 2022 and 2023 we have some changes in mind that should fix the issues
        - For older maxes - there's not much we can do. The problem is that in those Max versions Max itself doesn't support some of the possible controls in their Qt implementation. We ended up needing to implement the texture/material buttons from scratch and some of the functionalities (copy/paste f.e) are not exposed in the 3ds Max API at all so we can't implement them.
        Yavor Rubenov
        V-Ray for 3ds Max developer
          Just to clarify, there's nothing wrong when using Max 21 and Vray 5. I couldn't check 22 as I have 6 installed.
            V-Ray 5 is using the old controls for the blend material. We updated it only in V-Ray 6.
            Yavor Rubenov
              Yeah from what I am hearing. If you are using 3d max 2021 than Vray 6 is not fully compatible and time to update 3d max.
              Shame...
                Hm we might have found a solution for older Max versions too but it will take a few more days.
                Yavor Rubenov
                  You always come in with good news!!! lol.
                  Thank you,
                    Today's stable builds 31557 (https://nightlies.chaos.com/main#/vr...table/20220805) should contain some improvements here too.
                    Yavor Rubenov
                      Hello yavor,
                      I downloaded the hotfix 2 which was uploaded to main download site. Right click still not functional in Vray blend on max 2021.
                      Was this reverted back on the official release not to work again? :/
                        Works perfectly with 3ds max 2022/2023 and latest public build.
                          Yes, Yavor mentioned the bug was with max 2021. Thats why I am asking since I still use 2021.
                            The fixes only help for the texture buttons (the blend amount textures f.e). Unfortunately for material buttons - it is up to Autodesk.
                            Yavor Rubenov
                            • #15
                              So I am a little lost. Previous Vray it was working with and new Vray it doesn't work. I did not update anything in Autodesk. Using same version of Autodesk, just new version of Vray. Yet somehow Autodesk did this?
