Deep EXR output
  • Deep EXR output
    I'm running into an issue here where if I try to save out a deep EXR sequence in max using the V-Raw raw image file dialogue in render settings, the images just don't save. If I uncheck the deep EXR and just save as regular EXR everything is fine. I can save all render elements to single file from the VFB as an EXR for each frame but obviously can't do that for 600 frames.
    Hope that makes sense.
    Hi are you using progressive image sampler? Deep EXR is not supported with progressive image sampler.
    Vladimir Krastev | chaos.com
