Can't drag and drop textures in the VrayBitmap map since installing Vray 6 hotfix 1
  • Can't drag and drop textures in the VrayBitmap map since installing Vray 6 hotfix 1
    Since installing Vray 6 hotfix 1 I can no longer drag and drop my textures in the "Bitmap" field of the VrayBitmap map. I have to click the three dots and browse to the texture's location. Anyone else seeing this?
    Aleksandar Mitov
    www.renarvisuals.com
    office@renarvisuals.com
    AMD Ryzen 9 9950X 16-core
    96GB DDR5
    Thanks for the report. I've logged it (internal bug-tracker id: VMAX-12446).
      Originally posted by Alex_M View Post
      Wait,
      You can actually drag & drop textures from explorer to VRay bitmap?
        Thanks!
        Originally posted by DestinHalfmann View Post
        Wait,
        Yup. It's pretty neat. Or it was, to be more precise. If you are on a version older than 6 hotfix 1, it should work.
        Aleksandar Mitov
        96GB DDR5
          Today's stable builds 31557 (https://nightlies.chaos.com/main#/vr...table/20220805) should contain a fix for this. Only one case if the name contains frame numbers like image.0000.png is not yet handled - fix is coming in a few days.
          Yavor Rubenov
          V-Ray for 3ds Max developer
            Worked like a charm. Thanks!
            Aleksandar Mitov
            96GB DDR5
