Thank you so much for adding the right-click Select Lights in Scene to LightMix!
One small issue. When you select an instance ideally this would give you an option to select just one instance (for quick selection and editing), or to select all instances. However, when this feature selects multiple lights it is VERY slow. I think it is updating between each selection, rather than holding updates and selecting the entire list at once.
I guess if it could select all instances really quickly then perhaps selecting just one would not be required.
Anyway, great feature! Thanks again.
EDIT: It probably should select all instances, but it should do it faster!
