We recently installed Vray 6 on our machines, but we are having some trouble using backburner when rendering. When our machines are trying to load a scene through backburner we are getting an error.
2022/08/16 11:31:27 INF Adapter returned unexpected code -2 for "C:\Program Files\Autodesk\3ds Max 2022\maxadapter.adp.exe" "-o" "NewTask" "-l" "Info" "-j" "C:\Users\[user]\AppData\Local\backburner\Server Job\test.xml.details" "-s" "1" "-n" "1" "-a" "C:\Users\[user]\AppData\Local\backburner\Server Job\test.zip" "-d" "utf-8"
2022/08/16 11:31:27 ERR Task error: 3dsmax adapter error : Autodesk 24.3 reported error: [V-Ray] Error loading plugin library "C:\ProgramData\Autodesk\ApplicationPlugins\VR ay3d sMax2022\bin\plugins\vray_phoenix.dll": [loadLibEx] 127: LoadLibrary failed (127): The specified procedure could not be found.
2022/08/16 11:31:27 ERR 3dsmax adapter error : Autodesk 24.3 reported error: [V-Ray] Error loading plugin library "C:\ProgramData\Autodesk\ApplicationPlugins\VR ay3d sMax2022\bin\plugins\vray_phoenix.dll": [loadLibEx] 127: LoadLibrary failed (127): The specified procedure could not be found.
2022/08/16 11:31:27 INF Application is down
This happens in scenes where we use phoenx+vray and scene where we use only vray.
We are using 3ds max 2022, vray_adv_60008_max2022_x64 and phoenixFD_adv_50100_max2022_vray6_x64
On one scene I got the error 3 times and then it started rendering, but another scene would not start at all.
Is there anyone that has had this experiance?
