Metalness IOR Documentation Inconsistency
  • Metalness IOR Documentation Inconsistency
    Hello,
    Is there a reason as to why the VRay help doc on Metal IOR is different from the one posted on the blog?
    Blog Post:
    https://www.chaos.com/blog/understanding-metalness
    VRay Help Doc
    https://docs.chaos.com/display/VMAX/Metal+Shaders+IOR
    The reflection colors are not the same across the two charts.
    Plus the presets uses the reflection values from the blog post.
    I just want to be sure which chart to use.​​​​​​
    The values from the Documentation page are the correct ones. The difference stems from the more accurate metallic fresnel, which was implemented in V-Ray 6 and does not require pure white values for the reflection.
      Arh, I see.
      Good to know.
      Will the presets be updated to reflect this change?
        Originally posted by DestinHalfmann View Post
        Arh, I see.
        Good to know.
        The presets are already with the updated values. Tested it just in case with 6.00.08.
          Splendid!
          Thank you
