Decal Flicker in Video Only
  • Decal Flicker in Video Only
    I'm having trouble with the VRay decal flickering in animations. Please see the leaves outside the glass on the floor flickering (these are the decal) - when rendering the same frames (where the leaves are missing) individually, the appear normal.
    There is displacement on the stone floor material and no displacement on the leaves. As seen in the video: https://youtu.be/KuNI3-iQOEg
    Thanks!
    Hi could you share a bit more details about your setup? Are you using a mask in the VRayDecal? Are you using opacity maps for the leaf meterial? I will test a new simple scene now but it would be best if could send us yours here or trough our support contact form.
    Click image for larger version  Name:	3dsmax_2022-08-22_15-55-01.jpg Views:	0 Size:	40.9 KB ID:	1157749
    Vladimir Krastev | chaos.com
      Ah, I was using material opacity - will test with the mask slot in the VRayDecal. Cheers!
        Also the bottom of the decal gizmo might be too close to the surface; try to make the decal gizmo taller and going deeper below the surface.
