I think i posted my previous post in the wrong forum, so here again (Admin please delete the one at https://forums.chaos.com/forum/chaos...le-help-needed )
So here is my problem
Trying to set up a car render with motion blur, but i cant get it done correctly
Here is what i did so far
1. created a 3 frame scene
2. frame 0 i set a key for the car and the wheels
3. frame 2 i moved the car 5m and rotated the wheels on 180degrees
4. linked the camera and target to the body of the car
I tried multiple possibilities with shutterspeed, f-number and iso, but when only the complete car gets blurred
The goal is that only the wheels and the background/foreground gets the motion blur. The body of the car should be "crispy"
Here my camera settings
and here a test render, as you can see the vegetation is not blurred at all (using single meshes and some forest pack for the grass)
Note that I found a solution for the body of the car, did uncheck Default motion blur, inside vray object properties
But still cant get the background blurred
Scene should be similar to this:
Can someone help me to achieve this please?
