V-ray 6 Hotfix 2 - 3dsMax crashing
  • V-ray 6 Hotfix 2 - 3dsMax crashing
    I just updated to V-ray 6 Hotfix 2 for 3ds max (2021) and as soon as I open the material editor and try to do anything, Max crashes and closes with the typical message:
    Can you please help what might be causing this issue?
    Thanks
    should I just go back to vray 5? that at least worked..
      Could you attach the "3dsmax_minidump.dmp" file (it is located in the windows temp folder)? Make sure it is a recent one by crashing it beforehand.
        hello there
        cannot attach it as it exceeds file size limits, I've uploaded it here: https://files.fm/f/u2ndwzq64
        I hope this works.
          Hello,
          Thanks for the provided crash dump.
          You should clear crack files from previous versions and it should work.
          Yavor
          Yavor Rubenov
          V-Ray for 3ds Max developer
            hi,
            can you please elaborate on this? I'm not sure what to clear from where exactly.
              You have these two files:
              C:\Program Files\Chaos Group\V-Ray\3ds Max 2021\bin\plugins\vray_v41003_max_fix.dll
              C:\Program Files\Autodesk\3ds Max 2021\Plugins\vrayplugins\vray_v41003_fix.dlr​
              Those are not part of the official V-Ray installation and are known parts of the pirated illegal V-Ray.
              Yavor Rubenov
