Vray 6 proxy with modifiers + motion blur HUGE problem
  • #16
    EDIT: The correct build seems to have been capricious. Will update with the right info as i will get them.
    Lele
    emanuele.lecchi@chaos.com
    Disclaimer:
    • #17
      Hi, i've tried 31737 and it's still buggy. Also no note on the release notes. Maybe it didn't come out yet?
      • #18
        It should well have, but you are right, it doesn't seem to be in there, i just had time to test the same build out.
        I'll update my posts accordingly as i'll get more news.
        Lele
        Disclaimer:
        • #19
          So, the build with the fix is surely 31735.
          Somehow, it didn't make in the subsequent stable ones.
          The above, however is tested as fixed, please PM me if you need it and don't have access to it.
          I'll make sure to update the thread for when it'll be in stables.
          Lele
          Disclaimer:
          • #20
            It looks like the error was on my end, we don't have access to the nightlies, but rather to the stable versions. Could i please have access to the nightlies? There's no 31735 on the stables.
            Thank you
            • #21
              For now, just let me know via PM what max version you need covered, and i'll send you a link to the nightly. (it's quicker. )
              Lele
              Disclaimer:
              • #22
                The fix is now finally into the stable 31741 and later.
                Sorry for my misunderstandings.
                Lele
                Disclaimer:
                • #23
                  I've just tried both the nightly and stable and the bug is not fixed. Simply add a edit mesh modifier and the motion blur is gone.
                  Could you please confirm?
                  • #24
                    That would always be the case with any deformed geometry, independently from its source: edit mesh strips vertex animation.
                    Use turn to mesh instead. ​(see attached.)
                    Click image for larger version  Name:	image.png Views:	0 Size:	250.3 KB ID:	1165418
                    Lele
                    Disclaimer:
                    • #25
                      Edit mesh never broke before Vray 6, only Edit poly. We could edit the animated meshes (force example fix some poly ids) and not lose mb.
                      Here's a screen recording showing the bug with just a displacement mod.
                      https://streamable.com/kjguiq
                      • #26
                        It works for me with displacement, as you can see above, and it oddly (for me.) works with edit mesh as well, the proxy must be doing something clever enough (i.e.implicit turn to mesh).
                        We'll need a scene to repro this.
                        Lele
                        Disclaimer:
                        • #27
                          Sure here's the scene i'm using. I'm rendering frame 1006
                          https://we.tl/t-ckRoPdVins
                          • #28
                            I can repro the issue with your cache, i'll pass it on to the devs.
                            Thanks so much for the file!
                            Lele
                            Disclaimer:
                            • #29
                              Hello, any updates? Thank you
