Hello
I'm placing large amounts os vray proxies.
I already have points in the place whre this proxies should be.
I'm talking about 10.000 points separated 10 or 15 groups.
I have a script that calls "instancereplace" to replace de point nodes for the actual vray proxy.
Works fine but....after I replace some point groups this get very slow when I try to select the next group to replace.
It's slow just to select!! The script itself works great.
So...just thought that might has something to do with the proxies that slows things down.
Maybe it as something to do with the fact that they were instanced or with the geometry in the file because I've used a similar number of them (with much heavier geometry) with no problems.
Well....is you want I can send you a test file.
