Enmesh and opacity map
  • Enmesh and opacity map
    Something is wrong with this combination.
    Below render with mesh from Chaos Cosmos (Flowering Grass 91-13)
    left - source mesh, right - enmesh.
    opacity map clearly doesn't work
    Hi thanks for posting.
    You are right. After testing I can confirm that opacity map does not work with VRayEnmeshMod. Let me check if there are plans to upgrade this and if it is even possible and I will get back to the thread.
    Here is the result of my test:
    Refraction on the other hand works:
    Vladimir Krastev | chaos.com
      Hi again.
      I logged the issue under VMAX-12733 in our system.
        any news on that?
        many grass models use opacity maps ...​
